Stem rise: will I n...
[Closed] Stem rise: will I notice 1mm?
Apologies for what is potentially a stupid question. I'm looking to replace my aged ritchey stem at the moment. I have found a Thomson replacement but it differs slightly in that it is only a 5mm rise vs the 6mm I currently have. Is this so small as to be inconsequential?
Posted : 05/10/2010 12:53 pm
you'll crash and probably die.
don't do it.
Posted : 05/10/2010 12:54 pm
Straight over the bars you will go a sailing.
If you are sensitive enough to notice then you probably cried when Bambi's mother got shot (no you won't notice).
Posted : 05/10/2010 12:56 pm
Probably only feel like .8mm allowing for sag so should be ok.
Posted : 05/10/2010 12:57 pm
You won't notice.
Also, it'll be 1 degree difference, not 1 mm
Posted : 05/10/2010 1:01 pm
no
are you sure it's not 5 degrees vs 6 degrees rise?
Edit: wot clubber sed.
Posted : 05/10/2010 1:03 pm
DEpends, what colour is the stem?
Haha thanks. Knew I was asking for a pasting ๐Ÿ™‚
Posted : 05/10/2010 1:57 pm
Oh dear.
Posted : 05/10/2010 2:00 pm
Everyone will laugh at you, 5degrees/mm is so not trend
You will be a laughing stock on the trails
Do it
Posted : 05/10/2010 2:03 pm
Simply wearing a helmet should negate any adverse effects.
Posted : 05/10/2010 3:45 pm
increase the pressure in your front tyre by 1psi, that should bring your handlebars back upto the same position.
Posted : 05/10/2010 3:59 pm
or lower your stanchions by a few mm, that'll help it
Posted : 05/10/2010 4:40 pm
Depends on the length of the stem to whether you'll notice it or not. A Couple of metres long you'll notice it, trust me on this!
Posted : 05/10/2010 5:25 pm
METRES!!!!! dont think i need to trust you, i would believe it for myself ๐Ÿ˜†
Posted : 05/10/2010 5:27 pm
would your missus notice 1mm?
no I thought not.
nor will you. ๐Ÿ˜‰
Posted : 05/10/2010 5:40 pm
Did i miss a smiley off there? ๐Ÿ˜†
Posted : 05/10/2010 5:50 pm
