Stem 17-25 deg ..50...
[Closed] Stem 17-25 deg ..50-50 mm ?
 jeb
[#12330131]
Hello
Looking for this spec, had a look at Hope 50 mm 20 deg .... anything out there else ?
https://r2-bike.com/HOPE-Stem-318-mm-AM-Freeride-20-50-mm-silver
Posted : 07/04/2022 12:00 pm
BBB do some wacky stem angles.
Posted : 07/04/2022 12:04 pm
https://eu.ritcheylogic.com/eu_en/comp-4-axis-30d-stem
Posted : 07/04/2022 12:14 pm
You also need to t.i.c. the stack height, the shorter the steerer clamping area, the higher you can mount the stem. Which makes a diff. with short stems (5 degrees rise gives you about 6 mm extra height at 50mm length).
Posted : 07/04/2022 12:33 pm
I think the Rockshox and Fox guidenance states a max of 30mm of spacer between the headset and stem. So if you are maxed out on your spacers a short stack stem with some rise would yeild the same rise as a 40mm stack stem with no rise.
I've looked at loads of stems to try and get more rise, but eventually I chose the higer rise bar route. Surly Sunrise for the win 🙂
Posted : 07/04/2022 3:25 pm
 jeb
Thanks man, good info!
Posted : 07/04/2022 9:21 pm
