steerer/headset int...
[Closed] steerer/headset interface - whats an acceptable tolerance (hand filing content)
Not the best picture but was fitting a Columbus Minimal fork and Hope headset this weekend and when the fork was inserted it was binding in about 3 separate planes when I rotated the forks.
Got some calipers on the aluminium insert and there was about a 1/4mm difference between it and a RockShox steerer, not alot but enough to cause issues.
Gentle use of a hand file has sorted the issue and voided the warranty but are such issues common place or is this just a case that Hope are far more precise in their machining than a factory in China?[img] [/img]
Posted : 04/02/2013 3:56 pm
0.25mm is a lot when it comes to headsets - sounds as if the fork hadn't been faced.
Posted : 04/02/2013 4:13 pm
That's what I thought. As removing metal was always going to be the solution I felt an tiny file and an hours gentle rubbing/refit/rubbing would be the easiest solution rather than send it back and moan.
Posted : 04/02/2013 4:18 pm
