New (secondhand) frame and popped it all together but, steerer on my forks is too short - comes up halfway in my Thomson stem.
Has anybody tried this http://www.chainreactioncycles.com/Models.aspx?ModelID=3970 ? I guess a low stack headset could be an option but ideally I'd like c 40mm added.
Beyond new forks, any other tricks?
Low stack headset + low stack stem might gain you 20mm but your never going to magic up 40mm.
I wouldn't use an extender. Why do you need that much?
It's discontinued and have you read the first review ha!
I tried one of those a while back and it isn't what you think. It's more for converting a threaded fork in to a modern aheadset. Your best bet is a spank stem as they have the smallest stack height combined with a cheap on CRC crank brothers headset.
You need the old spank spike stem, not the new one. It has a 35 or 50mm reach, 26mm(!!!) stack height and also quite a significant rise.
Add in a M part low stack headset for £21
[url= http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=28122 ]M Part from CRC[/url]
And you should be there!
If you still need more, a 40mm riser bar is another option.
I've got a Spank Spike in Black & Chrome if you're interested - 35mm so it wouldn't be very helpful if you'd be doing a lot of climbing.
