Stans No Tubes Kit,...
[Closed] Stans No Tubes Kit, brand new ZTR Flows and normal High Rollers
OK, so now I've got this lot at home in the shed, having previously bought the Stans No Tubes kit when I had some DT Swiss 4.1 rims (leading to a failed attempt at a tubeless conversion...)
Am I right in thinking I have no need to use the rim strip, just the yellow rim tape? I guess I'll also need to buy some valves, as I'm not using the Stan's rim strip (shame to have to spend a bit more cash on this).
Or should I put the rim strip (with valves) into the Flow rims (extra weight, but maybe a better seal and saves having to buy valves)?
cheers
Posted : 07/09/2012 4:12 pm
No need for the rim strips with flows... yellow tape and a valve will do the job fine.
Dave
Posted : 07/09/2012 4:17 pm
OK, guess I need a quick trip to the LBS after work to pick up a pair of overpriced valves in that case. Hopefully the Flow rim wont need drilling and comes ready for a wider valve.....?
Posted : 07/09/2012 4:19 pm
Mine didn't... but the Stan's valves are presta anyway... ๐Ÿ˜•
Posted : 07/09/2012 4:22 pm
The instructions that come with the Stans kit say to drill out the rims to about 9mm even though the valves are presta, but maybe not necessary if you have a compressor to force the air in.
Posted : 07/09/2012 4:28 pm
the only time i've ever drilled rims is when using a rimstrip kit with a non-stans rim.
you shouldn't need to drill stans rims ever.
Dave
Posted : 07/09/2012 4:29 pm
Yup, just need yellow tape and valves. I have that exact setup and it was fine with presta valves (cores removed for initial seating) and no drilling.
Posted : 07/09/2012 4:33 pm
Good news, thanks
Posted : 07/09/2012 4:34 pm
I use the rim strips with my Flow's, found the tyres burped when downhilling with just yellow tape.
(thats why they make a Flow rim strip)
Posted : 07/09/2012 4:41 pm
