Stans Crest 29er ri...
[Closed] Stans Crest 29er rims and Bontrager tyres
Hi
A mate of mine is building me some 29er wheels and having bought some Bontager tyres off here, he says they are an incredibly tight fit and I mean incredibly!!!!
Other Bontager tyres on 29er Bontrager rims are ok
Anyone else had any problems?
This is 29er-just to emphasise
Steve
Posted : 07/06/2012 6:26 pm
Running 29er Crests with Bonty XDX tubeless ready tyres. Didn't have any trouble getting the tyres on at all.
Posted : 07/06/2012 6:42 pm
make sure he's dropped the tyre bead into the central channel before fitting.
Posted : 07/06/2012 6:49 pm
+1 Good Advice.
Makes a big difference, and also fit the tyre side opposite the valve first and work round, helps give you a little more slack.
I've found Maxxis ok to fit Crest 29er rims - Ardent, Beaver, and Crossmark all ok.
Posted : 07/06/2012 7:47 pm
seen lots of threads with crests being a pain to get tyres on - recently got some myself, and yes they are a bit tighter than the 355's they've replaced, but as above - make sure the tyre sits in the central groove and no problem (bonty and maxis tyres on with minimum fuss)
Posted : 07/06/2012 7:56 pm
I've swapped 5 tyres today (raining and kids to amuse). Mix of DT5.1, Stans 355's, Crest and FSA 29er, with crossmark, Racing Ralph, Bonty and WTB tyres. Only one I had bother with was an oldish Ardent on the Crest - couldn't get it to seal. Didn't try for long. Everything else went on and up fine with a track pump. You soon learn little tricks to get tyres on and up tubeless.
Posted : 07/06/2012 8:02 pm
As above it's all in the technique, I've fitted 4 tyres on Crest rims today (Bontrager 29.3, Schwalbe RR and 2 Conti Race King) and not had an issue getting them on at all. Once you've done a few they really are quite easy.
Posted : 07/06/2012 8:06 pm
