Stanchion scratch r...
[Closed] Stanchion scratch repair - is it actually worth it?
[#9306937]
So I scratched my lovely kashima coat on my Fox 32's whilst popping the seals out for a lube and greasing 😥
It is about 2cm long in an "L" shape; it can be felt when running my finger over it but I've removed any sharp edges. Is it really worth filling it and wet n dry papering? Or will I just wear more of the kashima down for little benefit? What do I risk by not filling it?
Posted : 03/05/2017 8:50 pm
I never bother, no ill effects to report - and I scratched my Pike stanchion about 18 months ago.
Posted : 03/05/2017 8:52 pm
I get some fine wet and dry and gently sand the rough edges, then leave it. Alway been fine, so far.
Got a few scratches on my 2 ride old Fox Transfer dropper the other day when bikes were being passed over fences ..... gave it a wee sand earlier tonight.
Posted : 03/05/2017 9:44 pm
I've used very fine wet'n'dry paper and then covered with clear nail varnish previously which did the job.
Posted : 03/05/2017 11:09 pm
Mate of mine used very fine wet n dry on a scratch on the shaft of his shock, just enough to remove any sharp edges.
That was a year ago, its still fine.
I guess if you do that and its leaking air (or oil) then you can investigate something a little more time consuming.
Posted : 03/05/2017 11:14 pm
IME on forks it makes no difference
My pikes got scratched about a week after purchase and I have never seen any additional wear or dirt in the oil /seals at service
As others note sand it so no sharp edges and try nail polish if a bit deep
PS its the old pikes so about 8 years use so far
Posted : 03/05/2017 11:22 pm
I scratched my Pikes and only varnished them for cosmetic reasons. Kashima? Use gold if you gonna do it!
Posted : 04/05/2017 3:41 pm
