SS speed ratios on ...
[Closed] SS speed ratios on a 29er
i was running 34:17 as that was a straight swop from my 26"SS, it has been suggested i should try a smaller chainring/sprocket because of the wheel size, is this true? if so what's ideal?
Posted : 03/09/2009 11:38 am
32:18 works for me.
Posted : 03/09/2009 11:41 am
Bigger wheel means a bigger gear for a given ratio.
32:18 on a 29er is about the same as 32:16 on a 26er.
34:18 on a 29er is about the same as 32:15 on a 26er. You're slightly higher geared than this.
Is the gearing working for you? If so, leave it. If not, either stick on a smaller chainring or a bigger sprocket depending upon what you have available.
Posted : 03/09/2009 11:43 am
ah, no wonder it was hurting a bit!
32:18 works for me
Because you is Ghey.
22:18 RD, its moutanus round there ๐Ÿ™‚
Posted : 03/09/2009 11:49 am
i hate to agree with spaghetti lover but 32:18 is good for me too
Posted : 03/09/2009 12:02 pm
๐Ÿ™„
Posted : 03/09/2009 1:48 pm
32:17 on a 650b is about the same as 32:16 on a 26er, but no one cares about 650B do they :-0
Posted : 03/09/2009 2:27 pm
My experience is that you can comfortably run the same on your 29er as on the 26" wheel even though it is a higher gear ratio.
Posted : 03/09/2009 2:41 pm
Gearing works out about 10% higher so drop 3-4 teeth on chainring or gain 2 on the cog.
Posted : 03/09/2009 2:43 pm
Except for you you wok smuggler.
Posted : 03/09/2009 3:12 pm
How rude!
Posted : 03/09/2009 3:13 pm
Too f*cking right.
Posted : 03/09/2009 3:20 pm
Fine.
Posted : 03/09/2009 3:26 pm
LOL.
You sound like the whiteshoeracer when she's go on one her. ๐Ÿ˜‰
Posted : 03/09/2009 3:31 pm
No I'm not a whiteshoeracer as "You've got to win" :-0
Posted : 03/09/2009 3:45 pm
So you make it 10% harder to push those pedals on a 29er. You must be lazy on your 26er.
Posted : 03/09/2009 4:19 pm
I run 32x18 most of the time; occasionally change to 32x20 for long hilly rides.
Posted : 03/09/2009 5:20 pm
 69er
Me too.
Posted : 03/09/2009 6:54 pm
 devs
My pal did NyA and CyB comfortably with 32:18 on his Gary Fisher 29er.
Posted : 03/09/2009 7:05 pm
nice 32T middleburn on it's way from CRC's sale
Posted : 03/09/2009 8:05 pm
I just tend to change the rear cog as its generally cheaper than a new chain ring, sorry RD a bit late for you now though.
Posted : 03/09/2009 8:28 pm
i've already got a rear 18T spare though so no probs
Posted : 03/09/2009 8:30 pm
I'm after a 20T for mine, mainly because I'm so fat and my commute takes in Burton Dassett country park twice a day.
Posted : 03/09/2009 9:54 pm
charlie is your friend
[url] http://cgi.ebay.co.uk/SURLY-TRACK-FIXED-wheel-cog-sprocket-20T-1%2f8_W0QQitemZ250429807531QQcmdZViewItem [/url]
Posted : 03/09/2009 9:58 pm
or if you want one for a cassette hub
[url] http://www.wiggle.co.uk/p/cycle/7/Surly_17T_to_22T_Cassette_Cogs/5360042473/ [/url]
Posted : 03/09/2009 10:14 pm
