Thinking of putting one on a Hardtail. Any pictures would be good. Tentative plan for going abroad with a 29er and 2 sets of wheels.
No but why wouldn't you?
EDIT break-away bikes are very good, pack as small and cost less?
**Ben to the forum**
[url= http://www.on-one.co.uk/news/teams-and-riders/q/date/2010/05/24/the-man-who-cut-his-inbred-in-half ]http://www.on-one.co.uk/news/teams-and-riders/q/date/2010/05/24/the-man-who-cut-his-inbred-in-half[/url]
Mate has em on mtb tandem, will direct him this way.
Plenty of custom-builders offer this option...won't be cheap though. I'd rather buy a S/H Ibis Tranny (bolt-on rear) or similar (If it had to be a hardtail).
Couplers don't save as much time as you would think, as you can still have problems with cables/hoses without removing parts.
I think a lot of full-sus frames would actually pack down smaller with them not having full size rear triangles.
Edit: Is your frame steel? I've just been reading that's what the frame would have made from...I think that only applies when altering existing frames though.
Yup, I've fitted quite a few to MTBs - they're plenty strong enough but yes, it has to be a steel frame.
Cables can have splitters, so you can separate the entire thing and have two halves to pack away.
I genuinely had not thought of splitting a full Sus at the Pivot for transport..Doh It's not as if my full suss has more than one.
It also looks as if the frame would need re powder coating/painting so a good second hand frame would be a good option.
Thanks for the links, that Inbred looks great.
Yep Crashtestmonkey has seen ours in action. We have a Ventana full bounce tandem with S&S couplings - 5 couplings to be precise to split the frame into three. Works very well too. I did not bother with cable splitters for the gears as I went for shifters that had seperate backets on the bars so when we pack it the grips, brackets for brakes and gears stay onthe bars and I just neatly coil and tape the hoses and gear cables in a loop.
Not sure if this link still works as work bans certain things but there was a little slide show of it being stripped and packed in this thread.
http://forums.mtbr.com/tandem-mountain-bikes/ventana-tandem-ss-couplers-436239.html
