As per title, I'm finding the downshift a little slow on the smaller cogs ie 9/10/11/12 on my XX1 Eagle set-up.
- drivetrain/cables are very new and also run-in ie month of usee
- top jockey wheel to cassette distance set as per SRAM b-tension tool
- frame hanger is aligned
Any suggestions please?
Posted : 02/11/2017 3:35 pm
I would guess either b-tension or cable is snagged/freyed somewhere along the way.
Posted : 02/11/2017 4:25 pm
The cable is fine so I guess it has to be fine-tweaking of the B-tension screw...
Posted : 02/11/2017 4:36 pm
This can be a slight issue on my Spark. I put it down to cable routing, and the pressure of the cable outer on the wire having a relative greater effect when the cable is slacker (i.e. bottom 3 cogs).
Posted : 02/11/2017 7:36 pm
Has the hanger been aligned by eye or with a gauge?
Posted : 02/11/2017 7:38 pm
