Sram XX1
[Closed] Sram XX1
[#4981436]
Anyone running this? I really like the principal but its just a tad out of budget for me just now. Will Sram trickle down the technology? I'd be interested to hear folks views on it, users or not, for and against etc.
Posted : 20/03/2013 9:43 pm
Will assume they will trickle down, would love to give it a go. Only concern I heard was a larger than normal gap between the gears, hence wanting to try. Would expect it in a year or so....
Posted : 20/03/2013 9:53 pm
 br
Having 'fondled' the cassette, if I had the cash, I'd have it.
Posted : 20/03/2013 9:56 pm
SRAM have said, quite reasonably, that they won't be trickling it down until they're convinced they've topped out the market of "people who'd buy 11 speed X9, but since it doesn't exist will buy XX1 instead". So could be a while.
I'd be tempted if Fulcrum did an XX1 freehub for my wheels.
Posted : 20/03/2013 10:01 pm
X01 has been specced for 2014 bikes.
It's coming.
Posted : 20/03/2013 10:15 pm
Will shimano be following suit with 1x11?????
Posted : 20/03/2013 10:44 pm
For a fit rider in an Alpine environment it's a game changer. 1 x 10 was too narrow a range for big climbs and big descents. With 1 x 11 it's do-able but you need a certain fitness level to make it work.
Posted : 20/03/2013 10:50 pm
Sounds like singlespeeding for pussies 😀
Posted : 20/03/2013 10:53 pm
It's got to be what we've been waiting for. A properly useful range of gears without the archaic, clunky, noisy front mech. Cash aside, all my bikes would be running it now. That, plus a clutch rear mech and a dropper post would transform a mountain bike, and I mean a proper mountain bike, made to be ridden up mountains, and especially back down them.
We're seriously living in the age where mountain bikes become seriously good pieces of kit. No compromise.
What lucky, lucky riders we are. Yes, you can have loads and loads of fun on your fully-rigid, single speed, seven-speed, hair-shirt 1.8 tyre'd dandy horse. But give me some suspension technology and component advancement and I'll take my fun to the next level.
Posted : 20/03/2013 11:38 pm
Scaled, you're right of course but single speeding up a 1500m climb and then down the other side is sadly beyond me!
Posted : 21/03/2013 7:00 am
Can't see Shimano doing anything directly comparable. Reckon the issue on lower groupsets will be getting a cassette that doesn't weigh a ton! Not sure X01 will be much of an improvement - an X.0 cassette is still significantly more expensive than XTR.
Posted : 21/03/2013 9:45 am
Strangely it seem to me to look a bit "low rent" actually on bikes. The idea is great though, just budget for new cassettes at £300 a pop!
Posted : 21/03/2013 9:47 am
I've got a week on SRAM XX1 behind me in La Palma. I ride with Schweiz quite a lot and both of us have just built XX1 bikes. My initial opinion is that it is very good. Chain retention was really good and I didn't suffer from the wide spacing between gears. On paper the 1x11 set up loses me a gear at either end of the spectrum over my 2x10 set ups. In the riding I did in La Palma I was ok on all the climbs we experienced with a 32 tooth ring up front and I noticed that I was using my bigger gear much more often than I did on 2x10... but I was never in a situation (on the trail) where I was spinning out my biggest gear.
Looking forward to testing it more in the Alps where the climbs will be somewhat steeper.
Posted : 21/03/2013 10:57 am
I would say it is inevitable that Sram move this technology down the scale - Hub manufacturers have put resources into making XX1 freehub bodies and i am sure many would not bother if they did not have assurance the range would expand.
In terms of the chainring teeth tech, it seems Sram dont own a patent so E13 some other new brand and Works Components seem to be getting in on it
From the
- facebook:
To be honest, i cant see 'standard' tooth single rings existing in the future, ill keep my eye out for E13's or a works ring so long as it is not £80 like Srams offerings!
Posted : 21/03/2013 12:25 pm
