SRAM X9 Jockey whee...
[Closed] SRAM X9 Jockey wheels help
On my old SRAM X9 the jockey wheels keep seizing up every 3-6 months. I've had enough of replacing them to have them seize up again in 6 months. Short of getting a new shifter and rear mech are there any places I could get jockey wheels with better bearings than SRAM?
Posted : 28/10/2009 3:05 pm
Do the jockey wheels not run on bushings not bearings?
How many times have you replaced them? The only issue I've had with them is them wearing out quickly.
May sound a silly question but are you doing too much maintenance?
Posted : 28/10/2009 3:12 pm
Bottom pulley is cartrige bearing, top is a bush.
Even when they sieze solid, I can always free them up in a few minutes (remove, hold centre race with molegrips, rotate outer race with pliers) Then leave them to soak in some thinnish oil overnight, cover in grease, refit.
๐Ÿ™‚
Posted : 28/10/2009 3:17 pm
thanks PP I'll try that. Should hopefully get me through the winter ๐Ÿ™‚
Posted : 28/10/2009 3:21 pm
Not had any seize on me yet but I'll note just in case.
mk1fan - I've got the old SRAM X.9 pre 2008, they've been know to have them seize up. I don't think the newer mech has the the same problem.
Posted : 28/10/2009 3:27 pm
I think I have a mix of pre and post '08 ones. I'll keep an eye on them ๐Ÿ˜‰
Posted : 28/10/2009 3:36 pm
Rather than 'keeping an eye on them' you'd be better taking them off, checking the bearing is OK, and smothering in grease before refitting.
A stitch in time etc........ ๐Ÿ™‚
Posted : 28/10/2009 3:38 pm
I have two sets, when they seize I take them off and leave in oil while I fit the set that had previously seized and left in oil (then freed up using a method similar to PP's above). Seems to work.
Posted : 28/10/2009 3:39 pm
BBB do replacement sets that do away with the bush.
My X9s siezed a number of times last winter despite being lubed with Web grease. Top pully on both mech are getting a bit sloppy so I'm goign to give the BBB's a shot this winter.
Posted : 28/10/2009 5:20 pm
 Kit
Mine do the same, although this set just wore out amazingly. Not very impressed, and I don't have the facilities to be leaving stuff around soaking in oil. Next time it happens, I'm going back to Shimano.
(P.S. You can use X7 jockey wheels to save a bit of money if you're replacing them)
Posted : 28/10/2009 5:28 pm
I filed the little tab off the cage on mine to fit a normal top jockey, the position of the wheel changes slightly but it works fine.
Posted : 28/10/2009 5:32 pm
Just get the BBB ones, they'll fit X7/9/0, and are sealed bearings top and bottom. I've got a set, just in case, but my existing six year old set are still going strong. Stet: the top one was replaced a couple of years ago when a tooth broke off.
Posted : 28/10/2009 7:26 pm
