SRAM X5 shifter que...
[Closed] SRAM X5 shifter question
[#872233]
My LH shifter has developed a bit of an issue.
It changes up the rings just fine, however when you go to change down the lever presses ok, but the front mech doesn't move all the way down to the next ring, if you move the bigger lever forwards you feel a small click and the mech drops into place.
The mech moves fine when moved by hand and the cable is slack/disconnected and the cables aren't jamming anywhere on their route.
Any ideas?
Posted : 16/09/2009 4:08 pm
Have you got a bent lever rubbing against the other by any chance, another thing to check is that the shifter isn't being pressed by the brake lever, this def. causes problems with Deore shifters, not sure about X5s.
Posted : 16/09/2009 7:05 pm
Nope, none of the above.
The levers are placcy.
Posted : 16/09/2009 9:33 pm
 diz
Steve i have some brand new ones you can have at CCm mates rates.
PM me via CCM
Posted : 16/09/2009 9:40 pm
Cheers Diz
I'll be over there tomorrow
Posted : 16/09/2009 9:41 pm
