SRAM X-9 rear derai...
[Closed] SRAM X-9 rear derailleur hanger mounting bolt - where from?
Need one of these as the one I picked up cheap from Ebay (bloody typical) for girlfriends bike has a hanger stuck rock solid onto it. I've manged to remove hanger and bolt but the bolt is about to round off and it's not budging.
Cheapest I've found is about £18 which seems outrageous and it would be cheaper picking up a whole knackered rear mech! Any suggestions, other than don't buy used gear on Ebay, appreciated.
Posted : 02/06/2012 5:30 pm
wtd on classified for a knackered mech or bolt would be the best. I gave mine away as i kept my broken one knowing someone would want parts.
Pretty sure they are all the same - well x0 and x9 are
Posted : 02/06/2012 6:03 pm
How do you get the bolt off the mech. There's the little black plate used with the b-tension screw but how do you actually remove the mounting bolt?
Posted : 05/09/2012 6:46 pm
circlip after the black plate towards the thread.
Remove this , black plate comes free and withdraw the bolt
Posted : 05/09/2012 6:49 pm
+1 Junkyard. It's a bit fiddly though. £18 sounds steep, I didn't pay that much when I replaced the bolt on my old 2005 X0mech.
Posted : 05/09/2012 6:51 pm
Int the derailleur mounting bolt type dependant on the frame?
I overtightened mine and got one from Goldtec for no more than £2.
Posted : 05/09/2012 6:54 pm
