sram type 2 vs 2.1
[Closed] sram type 2 vs 2.1
 snap
hi
I'm thinking of getting a xo rear mech , JE JAMES have them on offer but I've noticed that they are of the type 2 variety not the current 2.1 , this makes me wonder if the type 2 had problems so they solved it and renamed 2.1 ,
Any advice on this would be appreciated , thanks
Posted : 30/09/2016 6:10 am
The current one is 3 (Eagle); the type 2 clutch could loosen up, but at the same time you were able to open it up, clean, tighten, whatever.
They 'fixed' that by jamming a pin through the threads in the later iterations.
Posted : 30/09/2016 6:14 am
http://singletrackworld.com/forum/topic/sram-type-21-vs-type-20-rear-mechs-hmmmmmmmmmm
http://www.bikehub.co.za/forum/topic/146092-sram-type-21-rear-mechs/
Apart than it's probably older than 2014 so stock clearance stuff that should be on a decent discount ๐Ÿ˜‰
From a quick look type 2 (I ran one in x9) was a PTFE type bush that you could tighten, 2.1 became a roller bearing.
Ran for 2 years, still 100% after that (yes there was pivot play but it still shifted cleanly and solidly and the clutch worked well) still in the spares box
Posted : 30/09/2016 6:15 am
