SRAM shifter lever ...
[Closed] SRAM shifter lever not springing back
My 10 speed SRAM X9 shifter lever doesn't spring back after each shift. Is there a spring that is likely to have unsprung, or is it just hard to dislodge muck?
I took the back off and sprayed it liberally with GT40 to try and shift all of the gunk, but it looks as though I need to delve further into the gubbins - it looks as though bits will fly off everywhere. Is this a bad idea?
Posted : 25/05/2011 7:56 am
similar problem was an easy fix on my 9-speed X0 shifter. Opened it up, re-positioned spring that had popped out of hole, closed back up again. 10-sp X9 may be different though I suppose.
Posted : 25/05/2011 7:59 am
Common problem on the previous design 9-speed shifters. I tried following some instructions on line, but getting the whole thing back together was horrendous and I gave up in the end. If you can, try and get it warrantied.
Posted : 25/05/2011 8:34 am
lol, thanks for the conflicting replies! Have taken off the easy bit, but all of the springs I can see are seated OK, so I think it is deeper inside. I take it that loosening the large bolt holding the lever on will make everything fall apart?
Posted : 25/05/2011 8:50 am
