SRAM Shifter disman...
[Closed] SRAM Shifter dismantling - anything I should know first?
The little plug that covers the cable insert hole was mashed on my X7 shifter, so I had to push firmly on it to get it to turn.
I then found out that if you push a bit too hard you can actually push the plug into the shifter. Dang!
So I've gotta take the cover off to get the plug out, so that I can change the cable and use the shifter again.
I know there'sd all sorts of springs and gubbins in there, so any tips before I give it some spanners?
Posted : 15/07/2010 8:42 pm
it should all stay together, my x9 did
Posted : 15/07/2010 8:43 pm
I'll give it a go tomorrow night then ๐Ÿ˜•
Look out for the " how do I put all this back together" thread tomorrow :lol:.
Posted : 15/07/2010 8:48 pm
I've re-set sram shifters a few times, mainly to get the indicator bar in the right place.
You are right to be cautious because if you do knock a spring it will launch into semi orbit.
My top tips would,
* Do the whole job over something like a clean shoe box, that way you contain anything you drop and limit the travel of any parts.
* Use a magnetic tip screwdriver to remove the top cover, this allow you to keep hold of the shifter with one hand, unscrew the top and retain the scres.
* Take the cover of gently and look at where everything is.
Chances are doing the whole thing gently there will be no problem. have fun....
Posted : 15/07/2010 8:50 pm
No problem in the end.
Removed the 4 cover screws, carefully lifted the cover, nothing went boing, removed the offending plug, replaced the cover. Simples.
Phew!
Posted : 18/07/2010 7:21 pm
