I'm needing to replace the hoses on my levers but they have banjo fittings at the lever end.
My googling isn't coming up with much. Does anyone know where I can get a replacement set?
Ta.
This is the SRAM part number
00.5318.038.000
If in stock at zyro any bike shop with an account will be able to get it.ย
Failing that a jagwire or Uber bike kit
https://www.sram.com/en/service/articles/SRAM-Brake-Hose-Overview
I think you want to search for 'Beveled Banjo'
Oooft, was hoping for an AliExpress option!ย
Cheers folks.
Your didn't mention that anywhere
I just found this on AliExpress:ย
Bicycle Hydraulic Brake Hose and Needle Olive Connector Insert Banjo for SHIMANO AVID SRAM FORMULA Magura
https://a.aliexpress.com/_EyKAE7e
I needed something similar for routing my Apex set through integrated bars and the cheapest option I could find was Jagwire from Bikeinn.ย
Personally I wouldn't go cheap on safety critical parts and only use oe on brakes
I presume the above would work with Rival too?ย
I'm trying to drop bar my mountain bike, beginning to wish I hadn't bothered. It's costing a small fortune.
I think they're shared over the entire range of that age. I was swapping them from my old gravel bike to one I was building for my wife and was surprised when I came to take them off and I couldn't just use a generic hose.
iirc Uberbike do them too.
