SRAM power link que...
[Closed] SRAM power link question??
Hi guys
I fitted a SRAM chain wrong the other day, it was a brand new chain (, I just didn't put it thought the figure of 8 right...oops)
Anyway I used the power link and next day I figured out why the chain was noisy so I undid the powerlink and redid the chain the right way
Now I reused the same powerlink and it's still did the big click when I did it..and I still had to apply the rear brake to make it click....will this be ok ??
I know SRAM say it's a one time used thing , but the bike never left the work stand
Posted : 31/05/2016 5:31 am
It will be fine
Posted : 31/05/2016 5:35 am
I've split and reused them fine, not easy to split without the tool but never had any issues doing it.
lost count of how many times i've done that and I'm still alive if a bit brain fuzzy
Posted : 31/05/2016 5:37 am
Awesome...thanks guys..so I guess it's just another con in the bike world ๐Ÿ˜€
Posted : 31/05/2016 6:06 am
Power Links (8/9 speed) are reusable, Power Locks (10/11 speed) aren't by design, but in reality are fine.
Posted : 31/05/2016 7:10 am
I won't reuse Power Locks (except in extremis). You can see the wear on them once they're apart and the image in my mind of the potential injury should it fail under high load ensures that I only replace with a new one.
Posted : 31/05/2016 10:29 am
The only problem with reusing a Power Lock (over the lifetime of a single chain, of course) isn't that it will fail under load, but that it can become undone when the chain is slack (i.e. over rough terrain). In my experience, once a bit of grime makes its way inside, it is pretty unlikely that the link will open by itself.
Posted : 31/05/2016 10:41 am
