SRAM mechs seizing ...
[Closed] SRAM mechs seizing onto der hanger.
Anyone else had trouble with mechs refusing to unscrew? This one is the second that's stuck and been in 3 weeks
Posted : 17/02/2015 11:33 pm
My Sram X0 rear mech has seized a couple of times at the pivot point.. just got some gt85 in about it and worked it loose.. seems to be quite common..
Posted : 18/02/2015 12:03 am
We get quite a few high-end ones on brand new bikes that are very tight to remove when we check the hangers. Put a smear of copper grease on the threads if you're concerned.
Posted : 18/02/2015 7:46 am
It's not the very small (2.5mm) grub screw that you've forgot to undo is it? It's about 4' O clock as you look at the mech side on (on my x9 9spd anyway) I've forgotten this once and it was a right headache... Until the penny dropped??
Posted : 18/02/2015 9:12 am
Grubscrew?
Posted : 18/02/2015 1:36 pm
wysiwyg - Member
Grubscrew?
Ok it's not at 4 O'clock in the pic, more like 3 O'clock. Just above the Low screw adjuster
I guess not all mechs have these on them?
Posted : 18/02/2015 1:51 pm
Ah this is a type 2 clutch. But in all my years of sramship I can never recall seeing that grubscrew
Posted : 18/02/2015 5:35 pm
