SRAM hydraulic road...
[Closed] SRAM hydraulic road shifter (brake hose related)
Hi folks. I'm looking at a used set of the above on fleabay. Do I need to buy a brand new hose kit if the one that comes with the shifters is too short, no way to just replace the hose? (it's got a banjo joint at the shifter end)
Posted : 16/01/2022 5:04 pm
Pretty sure it's a crimped joint at the lever end (unless they've changed it since I tried to swap one).
Posted : 16/01/2022 9:21 pm
About £45 a hose,obv you can use the old rear for front and use new full length on the rear,I just purchased the only alternative which is the jagwire hose kit,about £28 delivered from europe
Posted : 16/01/2022 9:34 pm
 aP
I thought the connection was stealthamajig?
Posted : 17/01/2022 12:00 am
@swampi, yes thats what i was planning to do. Have you got a link to the jagwire kit?
thanks
Posted : 18/01/2022 5:31 pm
