Sram help needed
Sram help needed
Trying to help a mate out. He’s just bought a 2nd hand bike with a sram x9 shifter and an x7 mech on 10 speed cassette. New chain, cassette, cable inner and outer shifts ok but won’t stay in the lowest ( biggest ring ) at the back, shifts up ok but won’t stay there. Mech tensioned correctly as per various videos. What am I missing? I only use shimano. Is it new mech / shifter time? Also I have found x7 9speed and 10speed mechs but no idea how to tell the difference. I can’t see any serial numbers on the mech. Are they cross compatible?
Thanks In advance.
Posted : 22/10/2022 8:48 pm
Have you adjusted the low limit screw?
Posted : 22/10/2022 9:06 pm
I've had this occasionally when the inner cable wasn't seated fully during initial set up, and it created a near perfect single shifts worth of slack in the cable, gave exactly the symptoms you describe.
Posted : 22/10/2022 9:10 pm
