SRAM Guide RS to RE...
[Closed] SRAM Guide RS to RE Question
Hi all,
So, my Guide RS lever has well, given up on me today - literally went to swap the front pads, put them in - they were grabbing on the disc so i decided to bleed (i bled the rear earlier in the day and the bikes been sat for a good while) - well
Thats when the fun began, when i went to bleed, i cannot push fluid through from the lever side with the bleeding edge port open as per instructions, bearing in mind the rears went fine
As a result, the lever is also just loose now - does nothing and appear to be totally spannered
Whilst searching for a fix, i decided to just order a new set of fronts - well you cant get RS anywhere and i need them ready for the weekend
So 2 Qs really - any experience/fixes for the above issue and the next Q is
I could only get hold of the SRAM Guide RE as a replacement quick enough, seems it has the Guide R lever and Code caliper and has good reviews but:
- Will it fit on the Mounting hardware from the Guide RS to fork, seems its a weird CPS mount but it only looks like its washers and stuff that are different, will they come with the caliper?
- Will it be ok having a mix front and rear even though they are both 4 pots?
If that makes sense - cheers in advance
Posted : 12/08/2020 9:15 pm
Has it been in the sun. The newer Guides aren't meant to, but do you hav a sticky lever piston.
Both my Gen1 stuck after hot weather. Replaced piston and been fine since.
Posted : 12/08/2020 9:22 pm
Only for an hour or so today yes
Not sure what could be sticking, the lever itself is just flapping around and the little spring i can see appears to be very loose.
Pretty sure it was fine before i put new pads in..
Posted : 12/08/2020 9:24 pm
See what happens in the morning. The piston wont return once stuck.
Posted : 12/08/2020 9:29 pm
Went and had a quick look what its doing - its off the bike totally now but it appears the piston has come back out a bit as as soon as i moved the lever i felt it bite, however its gone back in and is now the same..
Maybe the morning will bring better news
Posted : 12/08/2020 9:43 pm
You may need to sand it down, but a new piston will cure it. If you need it ASAP, I'd sand the piston down and order a replacement
Posted : 12/08/2020 9:48 pm
Next question - i can get a piston from amazon on friday by the looks, decent reviews - what do you use as a circlip tool to get the clip out? No room in there for normal circlip pliers by the looks..
Posted : 12/08/2020 10:08 pm
I used 2 picks and a small screwdriver. I can't remember how, and it was a bit of a fiddle, but worked eventually.
Posted : 13/08/2020 6:47 am
Searching for "motorcycle circlip pliers" (or master cylinder pliers) on ebay should yield something like this:
Posted : 13/08/2020 8:07 am
