Sram guide RS slow ...
Sram guide RS slow lever return.
So they have been working spot on but since I fitted new headset bearings and new bars the rear lever is slow to return. They work perfect other than that.Think that it’s happened now is just a coincidence.
Will a bleed sort it or is it sticky pistons?
Tia
Posted : 28/06/2022 8:53 pm
Sounds like sticky pistons, happens when it get's warm if you've not replaced them with the revised ones. Try a bleed first though.
Try running some cold water over the body of the lever to cool it down to see if that changes it.
Posted : 28/06/2022 10:08 pm
Recently had to replace the lever piston on my Guide RS's.
Was easy to do and made a big difference to performance.
Posted : 28/06/2022 11:10 pm
Thanks , shall give it a go.
Posted : 29/06/2022 5:36 am
Loads of vids on YouTube for this.
Posted : 29/06/2022 7:22 am
Thanks Rick, will take a look tonight.
Posted : 29/06/2022 7:48 am
Anyone know which piston I would want for my guide RS levers, there are 2 lengths ,
2.6cm and 3.6cm. Would be nice not to have to strip them down to find out.
Also do I need any specific tools to do the job? Thanks.
Posted : 30/06/2022 4:44 am
Obviously you'll need a SRAM bleed kit, i think you'll need a 9mm Torx bit for the bleed too. (might be 10mm). Other than that, spend a bit of time taking it apart so you remember what way around the return spring goes, it's really easy to forget 😀 You then spend 20 mins thinking 'is it that way, or that way...or....' but it's a fairly simple if a little messy job.
Posted : 30/06/2022 6:23 am
Thanks weeksy, should be ok for those tools. Sounds like a job for a quiet Sunday morning.
Posted : 30/06/2022 6:43 am
Cheers everyone, just ordered two pistons, hopefully get them fitted at the weekend.
Posted : 30/06/2022 7:30 am
