Sram cranks, remova...
[Closed] Sram cranks, removal of wobble, and removal
Sram x1, never had one before and it has worked loose. Do I just tighten the 8mm bolt (seems too simple, what stops it falling off?) how do I remove the crankarm? Just loosen the 8mm and ignore the 10mm? It all seems too simple?
Posted : 08/03/2015 8:17 pm
Yes, it's all in the 8mm. Ignore the 10mm unless it's managed to work itself loose somehow.
Posted : 08/03/2015 8:23 pm
I never understood what the 10mm bolt was for when I had sram cranks
also I found they needed LOTS of torque to do up tight enough, but were actually surprisingly easy to remove after that
Posted : 08/03/2015 9:23 pm
It's a self extracting crank bolt.
Posted : 08/03/2015 9:24 pm
The 8mm bolt pushes against the 10mm bolt to pull the arm off. Some square taper cranks had a similar setup to work instead of a crank puller. My x1 cranks had a little wobble untill done up tight.
Posted : 08/03/2015 9:28 pm
So I just need to get the 8mm bolt up to torque again. Sounds like they weren't installed correctly by the lbs, or they loosen up slightly after initial use?
Posted : 08/03/2015 9:37 pm
Haven't had mine (XX1 cranks, but I'd imagine they're the same) loosen up, but they need to be done up pretty damn toight in the first place to remove play.
Posted : 08/03/2015 10:24 pm
48-54 nm when fitting. Has to be about the tightest bolt I ever do on a bike
Don't remeber seeing one come loose and have to use a big bar to undo them often
Some have a collar on the left hand arm to adjust the pre load some have shims and a wavy spring washer
Posted : 08/03/2015 10:53 pm
