SRAM Chain w/Powerl...
[Closed] SRAM Chain w/Powerlink...
Do you need a chain tool to fit chain from new?
Posted : 08/09/2012 2:31 pm
kinda. Unless the chain is the right length out of the box (highly unlikely) you'll need to chain tool to shorten it to the correct length
Posted : 08/09/2012 2:33 pm
Yes, you will need to remove some links to make it the right length for your bike.
OK - in that case, is there a rule for knowing the right length?
Posted : 08/09/2012 2:37 pm
 Taff
For a hardtail it's putting it in the larger ring at the front and smallest cog at the back. The mech hanger should be vertical.
For a full suss I think it's the same plus 2 links - may be wrong so someone will no doubt correct me
Posted : 08/09/2012 2:39 pm
Big ring to big ring plus two links is the rule I've always used.
(ignoring the rear mech)
Posted : 08/09/2012 2:43 pm
Cheers all.
Posted : 08/09/2012 2:46 pm
With a full suss, it varies depending on design, some have lots of growth and others don't. So I check it by removing the air or spring from the shock and squashing it.
Posted : 08/09/2012 2:54 pm
Cheers Nw - The chain is going on a HT but i'll remember that for future ref.
Posted : 08/09/2012 7:02 pm
