Sram brakes/shifter...
[Closed] Sram brakes/shifters question.
[#6985209]
I have a bike that comes with the reverb/shifters/brakes all in one clamp I think it's called matchmakers??. Anyway, if I want to change the brakes in the future does that leave me with only using sram stuff that's compatible?
Posted : 08/04/2015 5:45 pm
The shifters mount fine without brakes but your brakes will need clamps to be used on another bike (£40)
Posted : 08/04/2015 6:00 pm
It's called 'Matchmaker X' - the 'X' is the all in one system.
If you want to upgrade your brakes, it'll look neater if you go with a Matchmaker X compatible lever, that's for sure.
If you go with something else, I think the existing Reverb remote/shifter clamp can still be used without the brake lever body clamped inside it, so that only means 2 clamps overall, which isn't bad.
Posted : 08/04/2015 6:28 pm
In case you're not supposed to mount your clamp without a brake lever body held within it, you might be able to get hold of the following part to fill in the gap:
http://www.amazon.co.uk/RockShox-Hydraulic-Remote-Discrete-Remotes/dp/B00CZD7IXW
My Reverb lever came with one fitted (I don't have SRAM brakes).
Posted : 08/04/2015 7:21 pm
