Sram 12 speed casse...
[Closed] Sram 12 speed cassette lock ring, Where from?
[#11057133]
I need a spare lock ring for my xo1 12 speed 10-50 cassette but I'll be bu$$ered if I can find one online. Does anyone know if an 11t lock ring would fit and if it matters if its a sram or shimano one?
Posted : 20/02/2020 12:49 am
I'd be inclined to try some if you have any lying around. Should be very evident if they will fit or not.
Other than that, it might be worth a call to a few lbs to see if they have one laying around or, more likely, can try and order one from sram?
Edit: sorry,tired at the moment, is there even a lock ring on the 12spd??!
Posted : 20/02/2020 12:55 am
That was my first thought. I'm only on 11 speed but the SRAM and Garbaruk cassettes I use on XD drivers for those don't use lock rings.
Posted : 20/02/2020 5:41 am
SRAM XD cassettes don't use lockrings, once you strip the (quite fragile) spline/teeth the cassette becomes scrap.
Posted : 20/02/2020 7:26 am
I've got a scrap 11 speed cassette at home, might see if its possible to pull the centre out and transplant it.
Posted : 20/02/2020 8:47 am
Just taken the cassette off and the lock ring is indeed integral to the cassette. Doh!
Posted : 20/02/2020 11:42 am
Careful when refitting I partially borked a gx cassette by letting the tool slip on the cassette splines. Doh!
Posted : 20/02/2020 12:08 pm
Make sure you use a cassette tool with nice deep splines, shallow ones will just bend the internal teeth on the cassette
Posted : 20/02/2020 12:32 pm
