Spoke calculation- ...
Spoke calculation- sense check these measurements & specs please
I'm building up my first ever wheelset which I'm looking forward to.
Spoke lengths has me being a bit cautious though.
Specs on the wheels:
- Hope Pro 4 Boost 110 front
- Hope Pro 5 Boost 148 rear
- DT Swiss U 663 20" rims
DT Swiss spits this calculation out for me, but it doesn't look quite right..
spksov
Surely what I want is: 32x 183mm & 32x 184mm ?
- Spokes; think I'll go for double butted 2.0/1.8 spokes
- Nipples: Some DT Swiss brass 14mm nipples
Would welcome any thoughts and advice!
Cheers all.
Posted : 08/11/2024 10:32 am
What spokes did you select on the DT tool? I think it can give (slightly) different numbers for different spokes. Also make sure you have selected the correct nipple.
Posted : 08/11/2024 10:38 am
If there's only 1mm between the spoke lengths I'd probably just round up and get them all at the longer length.
I usually plug the numbers into a few different online calculators as well, as they do vary a bit.
Posted : 08/11/2024 10:41 am
Yup, good point- spokes were the Competition 2.0/1.8 & nipples brass 14mm.
Full spec:
spokess
32 x 182mm and 32x 184mm...
Posted : 08/11/2024 12:17 pm
Thanks all! Ordered 182mm & 184mm.
Looking forward to building these up ?
Posted : 08/11/2024 7:10 pm
Spokes stretch a mil or so when built so it's not entirely unreasonable to round down a bit as per the calculator above.
Posted : 09/11/2024 1:06 am
