Does anybody know of the lock on grip style lever that comes with a spesh command post will work with an ergon grip at all ?
If not will it lock onto the bars without being connected to the end of a grip ?
Cheers.
Steve.
Should be a rubber insert that allows it to go straight onto the bars. It will also fit most lock on grips by using the clamp insead of the lock on ring
Renton, I've got the 'southpaw' remote going spare if your interested?
i said to you chap if you get stuck theres grips for it , just take the grip end off (clamp) and lever fits over a small plastic ridge on the grip replaces the clamp with a lever clamp.....its a pretty clean setup
if you are interested I have a spare specialized under bar shifter type lever for the command post
Mickmcd. That you did mate.
I like to use ergon ge1 grips now mate but not sure if the clamp is slightly different to a normal (like odi etc) lock on clamp.
Cheers.
Steve.
no worries thanks for the reply
saladdodger and treklee - how much are you asking for your remotes?
apologies Salad, thought i had replied to you at the same time as replying to Mick.
I will pass on the lever thanks, prefer the style that I have !!
The lever is brand new un used £25 posted
Saladdodger. If the lever dosent sell I will have it please
trekked - did you post the lever? Nothing arrived yet.
treklee - cheers fella.
How would you attach that to bars silly billy
treklee......... Have you posted it yet? Even a disorganised new Dad is stretching it now - 5-6 weeks...
treklee/Lee/Liam - Two months and still no remote trigger. I may be passing Stourport soon so could pick it up if posting is a big problem?
Can you get in touch please. Or just send a refund.
