Specialized tyres -...
[Closed] Specialized tyres - help me out
Looking for an all rounder set of AM tyres, something equivalent to Hans Dampf, so
2.35ish
Reasonably light (800g ballpark)
Grippy
Decent on roots, cope in mud
Tubeless ready
Looking at the CLutch SX,don't think it comes in tubeless, does it?
Posted : 18/12/2012 10:56 am
how about hans dampfs?
Posted : 18/12/2012 10:58 am
butcher?
Posted : 18/12/2012 10:59 am
Anyone using the butcher? How do they rate?
Posted : 18/12/2012 11:02 am
Let me rephrase... why do you want specialized in particular? If you want 'something equivalent to Hans Dampf', why not just use hans dampfs?
Dave
Posted : 18/12/2012 11:10 am
I've got a 2.3 Butcher on the front of mine and after one relatively short afternoon's riding I'm impressed. Nice and grippy but also roll pretty quickly.
Although haven't tried them in muddier conditions yet.
Posted : 18/12/2012 11:11 am
alfabus - Member
Dave
Already on them - just investigating alternatives, seeing if there's something better out there.
(I don't want to write "because I'm a tart" but I will if I have to)
Posted : 18/12/2012 11:13 am
how about the new purgatory 2.3 !!
Posted : 18/12/2012 11:16 am
๐Ÿ˜†
I'd have rated Schwalbe higher up the 'tart' tree than Spesh though.
Dave
Posted : 18/12/2012 11:18 am
Butcher Control 2Bliss? Should be available properly any time now (rather than random odd sets not officially available in the UK, hence sporadic supply).
Minion EXO? Similar rolling resistance to an HD, yet noticably better grip?
Not tubeless ready but mine have gone up on Flows, Arch EX's & Haven rims with a liberal use of soapy water & a crap Park track pump.
Posted : 18/12/2012 11:38 am
Aren't the Minions more biased towards dry conditions, HN?
Am on Crossmax SX, not sure about non-tubless tyres run tubeless on UST rims
Posted : 18/12/2012 11:49 am
I haven't used the Hans Dampf, but the Butcher Control's the best front tyre I've used for ages. Not fast rolling, but then it's the size of a 2.5 minion. Grippier than a maxxpro, slippier than a supertacky, clears better and grips better in mud and slides nicer when it slides. Doesn't seem quite as good on hardpack, but not far off it.
The SX tyres aren't officially tubeless but they act like they should be. Clutch isn't as standout a tyre IMO, it's decent but it doesn't shine, and tbh the Butcher is better than it in most conditions bar the dry.
Posted : 18/12/2012 11:56 am
Sounds good then. I dunno what dry is, have heard of it, but not seen it.
Posted : 18/12/2012 11:57 am
I've got an Eskar on the front of my Pitch and it's great, I suspect it's probably for dryer conditions than the Hans Dampf which looks more like the Purgatory.
Posted : 18/12/2012 12:01 pm
The Butcher is a slightly lower profile version of the Minion but very, very similar, so ride like a Minion, perhaps with a little less drag on hard ground.
Minion was originally used for that, but a lot of people use them for everything (me included). Only time I tend not to is in deep, thick mud. Otherwise they work well for me.
I've tried some HD's and they were pretty good also, just lacked the outright grip of a Minion, more noticeable when leaning the bike over or on off camber sections - the side lugs on the Minion seem better.
Non tubeless tyres work on UST rims - as ever it depends on the combination to a certain degree. These Minions went up as easily as the 2Bliss Spec's I have as well on an Easton UST rim.
Posted : 18/12/2012 12:04 pm
Purgatory 2.3 front Eskar rear at the moment.
New Purgatory is geat in slime.
Posted : 18/12/2012 12:07 pm
Eskar's a fairly hard-feeling tyre, I quite like it on the rear (as it's knobbly and big, but fast) but it's not what I'd choose for this. Good though.
Re Butcher vs Minion... I've not had them side by side to compare but it doesn't seem lower profile. The main difference is the knobs are more spaced out and regular, which I reckon is what makes them better in mud.
And yup, most Maxxises tubeless up absolutely fine- quite a lot of rubber in them which makes for good sealing, and the carcasses are good quality. Only ever had one that wouldn't IIRC.
Posted : 18/12/2012 12:09 pm
