Im looking to change the pivot on a Stuntjumper can anyone point me in the right direction as to what I need to do? or what tools I need to do it.
Firstly it's a Stumpjumper, which might make googling easier. Which pivot, there a few. They can mostly be done with bits if studding and various sockets to push the old bearings out and the new ones in. Just hope the bearings don't break as then it can be a pain.
Do you mean the bushings? Contact betd.
The ones loose, that's seems like you have to get the crank out to change it or remove. I would rather try it myself before going down to the lbs. Has anyone changed it before? Give instructions
What's the magic word? ๐
Aplogies, please on the end ๐ณ
Sounds like you mean the main pivot. That seems likely as they tend to go first.
Remove cranks, front mech/chain device and rear wheel.
Undo big pivot bolt (Allen key one side, socket the other.
Remove bolt (can be tight) and drop rear suspension. Don't lose the spacers.
Push each bearing out from the inside (make a bearing pusher from a socket, studding, washers and nuts)
Use a similar tool but bigger socket to put the new bearings in
Replace bolt, spacers and rear suspension.
Its not tricky but go careful because if you do break the bearing it becomes a much bigger job.
That's great, do you know where I can get the bearing kit from
Anyone know where I can get the bearing kit from?
Or for better quality: http://www.ebay.co.uk/itm/Specialized-Bearing-Kit-Stumpjumper-Sworks-Saphire-2007-/141407159118?pt=UK_Health_Beauty_Fragrances_Women_s_Fragrances_PP&hash=item20ec86034e
There is a difference between 06 & 07 though.
That's great thanks, im pretty certain the bearing itself has to be changed - is there anything I need to be wary of when doing?
As above the only tricky bit is if the bearing falls apart and leaves the out race stuck in the hole. If if does its dremell time
But those bigger ones don't often do that
