Specialized Pitch p...
[Closed] Specialized Pitch pro 2010 SHock Bushings Help.
Just wondering is anyone on here could help me out with what size/type of rear shock bushing I will need to replace the worn shock bushing on my 2010 Specialized Pitch Pro with a fox dhx air 3.0? Its just the bottom shock bushing that needs replaced. Any links or information would be much appreciated.
Rags
Posted : 17/02/2014 11:34 am
[url= http://www.tftunedshox.com/info/mount_kits_bushings.aspx ]TFT tuned info page[/url]
Fox are 12.7 mm (1/2")
[i]More about Eyelet Bushings
As well as size variations, we also offer eyelet bushings in different materials. We recommend polymer eyelet bushings for heavy-duty mount kits as they resist deterioration under cleaning with chemicals (e.g. Muc-Off), and usually last longer, and supply this type with our mount kits. However, we also supply metal bushings if you prefer, check out here. Cane Creek shocks take their own specific eyelet bushings although the rest of the kit is the same[/i]
Posted : 17/02/2014 11:48 am
