Specialized Camber ...
[Closed] Specialized Camber 29er 2017 -what size shock?
Can anybody tell me what size shock is fitted to the Specialized Camber 29er 2017 (lime green)please? I've used a bit of google-fu but couldn't find a definitive answer
David
Posted : 07/01/2018 10:24 am
Think they are a different mount to normal shocks so you may struggle to find replacements.
Posted : 07/01/2018 10:31 am
197x51mm for the Evo 2015.
205x53mm for the Red/Green 2017.
Not sure which you meant?
Posted : 07/01/2018 11:49 am
Hi, thanks
Yes, appreciate that they are different fittings.
My bike is the base 2017 29er alloy frame in the green, one model bellow the comp
Posted : 07/01/2018 12:04 pm
205x53 I have the very same bike
Posted : 07/01/2018 1:12 pm
Brilliant, much appreciated. The o2 RL that is currently on it isn't the best and the lock out doesn't work
Posted : 07/01/2018 5:41 pm
Yeah mine seems to have very limited amount of adjustment....either fast rebound or slightly less fast 🙄
Although Id suggest sending it away to Tftuned or similar for tuning as itd probably work out cheaper than another shock
Posted : 07/01/2018 6:10 pm
The Float on my 2017 Carbon Comp seems alright, might be worth looking for one 2nd hand from someone upgrading?
I’m not sure there’s many options though? Will you need a bike yoke?
Posted : 07/01/2018 6:46 pm
