Specialized Camber ...
[Closed] Specialized Camber 15 EVO BB ? Confused - help !
[#9488387]
Hi all,
So the spec sheet says :
Cranks - Custom SRAM S-1250, 7050 alloy arms, 10-speed AM double, PF30 spindle, 36/22
With
Bottom Bracket SRAM, PF30, OS press-in bearings, sealed cartridge.
Anyone provide me with a linky to a replacement ..
New to this PF business and don't know which to get as a direct replacement.
Thanks muchly
Posted : 12/08/2017 5:25 pm
[url= http://singletrackworld.com/forum/topic/pf30-help-if-you-would ]my earlier thread on same subject[/url]
I went for the hope option and changed to a 1* setup at the same time using a Shimano xt crank that I already had with a 24mm NOT the standard 30mm axle. There's a version of the Hope BB that is 30mm axle friendly. I also put a sunrace cassette on at the same time.
The SRAM crank is insanely heavy iirc. Hence the switch along to the nice spare XT ones.
Posted : 12/08/2017 5:32 pm
[url= http://www.chainreactioncycles.com/mobile/fsa-bb-pf30-mtb-bottom-bracket-pf7000-/rp-prod129795 ]i THINK this one would be a cheaper straight swap[/url]
Or this
[url= http://www.chainreactioncycles.com/mobile/sram-pressfit-30-alloy-bottom-bracket/rp-prod51600 ]or a sram one[/url]
Posted : 12/08/2017 5:37 pm
The Sram BBs are not very good . For a little more money you could go for a wheels manufacturing PF 30 BB that is more durable and has replaceable bearings , rather than having to replace the whole thing when it wears out .
Posted : 12/08/2017 9:42 pm
