Speciaized Camber P...
[Closed] Speciaized Camber Pro rear mech hits swingarm. Help needed
I have a Camber Pro and I'm currently running 3x9 XTR. I have a M971 rear mech but when I go down the cassette the mech hits the frame.
What 3x9 mech are you running?
Would the M972 shadow long cage work ok?
Your thoughts would be welcome.
WD
Posted : 30/05/2011 8:40 pm
Try shortening your chain by a couple of lengths.
Also make sure that the B tension screw is adjusted correctly, so that the top jockey wheel is sitting just below the sprockets, not on them/
Posted : 30/05/2011 8:49 pm
B tension screw is as far as it can go.
I'm sure the chain is the correct length...
Posted : 30/05/2011 8:53 pm
*bump*
Posted : 31/05/2011 8:02 am
Take it back and explain the issue, simples
Posted : 31/05/2011 8:03 am
Not really, I bought it as frame only.... ๐Ÿ˜‰
Posted : 31/05/2011 8:05 am
You seem to be sure your chain is OK; but in a word of advice to anyone else reading this: Don't go shortening the chain unless you can positive that it needs it. Don't ever just 'take a couple of links out''. You can cause all kinds of grief by running a chain which is too short, especially on a suspension frame.
Whos_Daddy, does the mech hit the frame when you're in any of the front gears in particular?
Posted : 31/05/2011 8:12 am
The chain is the correct length.
The mech hits when I'm in the bottom 3 gears on the cassette in any chainring.
This is the part of the mech that hits the underside of the swingarm.
Posted : 31/05/2011 8:17 am
The last couple of years of spesh full sussers (at least) have so much slack if you put them in small/small that a long cage mech can't take up the slack. Its all to allow for chain growth, so I can echo 3Fish.
Spesh's of previous generations have had the mech hit the frame too. Their solution was to put a rubber pad on the mech knuckle. Is this where yours is meeting?
EDIT.
Looking at the impact point, I think a shadow mech is likely to help. It'll put the body further back and lower down, which, if you're lucky, will give you the clearance you need.
Posted : 31/05/2011 8:19 am
Cheers all.
I guess I'll try a shadow mech. Anyone have a M972 they want to sell??
Posted : 31/05/2011 8:26 am
The top (smallest) three Shirley? (just checking!)
Posted : 31/05/2011 8:38 am
the smallest cogs..
Posted : 31/05/2011 8:56 am
It's just one of those things that happens with Shimano mechs and 4-bar frames.
Spesh used to supply a little rubber bumper that zip-tied to the mech to cushion the knocking.
The best cure is a mech that doesn't pivot forewards at the cage, like SRAM. Don't the newer Shimano mechs also only pivot backwards as well??
Posted : 31/05/2011 9:01 am
My XTR mech came with a rubber section which you could remove. I don't have a Specialized Camber, so I'm afraid I cannot help.
Posted : 31/05/2011 9:09 am
