Spare anchovie/plug...
[Closed] Spare anchovie/plugs?
Anyone know if you can buy these things? got a couple of kits but no plugs left.
Posted : 08/07/2015 2:46 pm
I've seen them on eBay recently.
Posted : 08/07/2015 3:07 pm
 Bolt
Ordered, cheers guys
Posted : 08/07/2015 6:54 pm
What about the fluid? Is it just normal vulcanising solution? Got the Weldtite plug kit and can't tell.
Posted : 08/07/2015 7:25 pm
Going by what's in my panaracer kit, an old inner tube and a tube of bog standard rubber/vulcanizing solution should do the trick.
Posted : 08/07/2015 7:29 pm
 Bolt
No glue needed with those, they are just pushed in to plug the hole.
Bolt
Posted : 08/07/2015 7:47 pm
If I ride tubeless, some alpine stuff, I usually take a tube with me. But do I need one of these anchovy kits and can anyone recommend one?
Posted : 08/07/2015 8:26 pm
The Weldtite ones go for a fiver online. Five plugs, couple of insertion tools and a little knife to trim the plug when done. Comes in a little box, and will do for ages if you buy some of the above refills.
Posted : 08/07/2015 8:31 pm
I've had two lots now, the first needed a 3rd slicing off to get them into the insertion tool (didn't bother with the first and it took 10 minutes with some pliers getting it through)
More recently I got another refill, these are double the thickness so chopped them all in half lengthways. I even chose an auction where they seemed slimmer than the others!
Has anyone found a seller of cycle sized anchovies?
Posted : 08/07/2015 9:48 pm
Posted : 09/07/2015 8:40 am
Aye, it's just normal vulcanising glue.
Posted : 09/07/2015 8:47 am
I cut all my weldtite anchovies in half. Plenty long enough (you still end up trimming most of it off).
Posted : 09/07/2015 8:50 am
Weldtite rubber solution available [url= http://www.hargrovescycles.co.uk/weldtite-rubber-solution.html ]here[/url] for example.
I just bought two tubes, expecting them to be the same size as the tiny ones in the kits - but they are much bigger!
Posted : 09/07/2015 10:39 am
There is vulcanising fluid and rubber cement. They're not the same thing. Anchovies/weldtite plugs don't need either, the other weldtite kit which relies on strips of rubber cut from a sheet needs rubber cement.
Posted : 09/07/2015 11:19 am
The Weldtite kit comes with a tube of stuff. I just wanted to know what it is, as I can't tell. Seems like vulcanising solution to me but not sure.
Posted : 09/07/2015 1:44 pm
The stuff in the Weldtite kit is the stuff I linked to a couple of posts above.
As Scienceofficer pointed out, it isn't vulcanising fluid.
Posted : 09/07/2015 2:14 pm
The panaracer kit is pants. None of the plugs stayed in. When the same hole was repaired with a Weldtite kit it was good.
I bought some more plugs off ebay but they are way too big to work with the weldtite tool, might end up putting them in the bin. Can anyone link to a specific product that is the same size as a weldtite plug/anchovy?
And +1 for cutting the weldtite plugs in half. If you're careful fitting, you don't need the full length.
Posted : 09/07/2015 3:45 pm
As above most of the ones on EBay are a bit thick for the tool to be used properly. All I do is pull them apart lengthways to halve the thickness and then just trim to length. The ones I have are made up of 4or 5 thinner strands
They are kinda made up in the same way a rope but sticky (obviously) and this means you get even more for your ££
Carlos
Posted : 11/07/2015 1:11 pm
Hmn, I'll have a go pulling one apart, cheers.
Posted : 11/07/2015 11:03 pm
