Just building a new bike, and am a bit stumped in terms of tightening up the front disc rotor:
The front wheel's a 15mm hub (DT Swiss M1600) with centrelock rotors. Problem I've found is that there isn't enough space for my cassette lockring tool to engage the rotor lockring (because the hub flange is in the way). Can anybody both
- understand what I'm trying to explain; and
- offer a solution?
cheers
Had the same problem myself fitting a Magura rotor to a saint hub. The fins on the rotor stuck out so I couldn't get the tool to engage, the way I got round it ( and ought to work for you) was to use a socket tool that fits over the top of the lock ring and gives you a bit of depth to work with
Something like this
[url= http://http://www.cyclesurgery.com/whyte-stirling-2012/hybrid/bikes-components-bikewear/fcp-product/31056 ]Crc[/url]
thanks for your advice on this, Pridds.
Your link doesn't seem to work, though...?
Pridds has the answer with that different lockring. DT Swiss do one very similar and I'm surprised that there wasn't one supplied with the hubs.
thanks chaps; I'll check the bits and bobs that came with the wheels to see if there's an oversize lockring in there, but thought they were only supplied with a 6 bolt adaptor.
Failing that I'll get hold of a new one. Seem to be quite rare based on a quick google
thanks again
