Just replaced my outer chainring with an e-13 bashguard and running 22/36T. Now when i look at the chain line it could probably benefit from moving the drive-side crank out a bit. Where can I get a spacer from?
Cheers as always.
I have a ubber spacer from a race face bb. Have given up on external BB! so have the 3 2.5mm spacers.. if you want one email me your addy and i can post it tuesday?
...the other side of the bb shell. the pedal spindle is a fixed length and if you just put in an extra spacer then it will not do up properly. The best you can do if it is a 68mm bb shell is move a spacer from the non-drive to the drive side. This moves the whole crankset across 2.5mm. This might mean you don't have a great deal of thread left in the bb shell on the driveside bb cup. And this will make your bike wonky. I'm sure someone will be along in a bit to say whether or not 2.5mm 'out' makes a difference to your position on the bike. Never tried it mesself.
