Source a Fork for a...
[Closed] Source a Fork for a gravel bike
I would like to change the fork on my Orro terra gravel to get a  a bit more tyre clearance. Currently I can only fit a maximum of 32mm tyre on the front, rear can comfertably fit a 35mm probably even  a 38mm.
The fork rake is 43mm and the axle to crown is 378mm,  something with a thru axel that gets as close to those numbers as possible. Ideally carbon with mudguard eyelets.
Dont mind ordering from Chinese supplier if anyone sees this spec available. Nearest I’ve seen is Planet X London Road fork which meets the requirements except is QR not Thru axel.
Thanks in advance
Posted : 17/06/2018 10:15 pm
Would you really trust a Chinese fork over a British company with British standards on a fork? 😱 Just for bolt thru?
Posted : 18/06/2018 12:59 am
 cp
Your axle-crown length very much restricts your options unfortunately - most ''disc 700c" forks are aimed at CX and have an axle-crown more like 398 - including the London road you mention.
Posted : 18/06/2018 6:54 am
 rone
TRP fork
Posted : 18/06/2018 7:20 am
 rone
TRP fork
TRP cx fork
Still longer on the axel to crown.
Posted : 18/06/2018 7:22 am
Yes everything seems to be in the 390-395mm bracket. London Road is the shortest at 390, what effect would this increase have to the feel of the bike?
Enve looks perfect but that is too much cash for a fork.
Posted : 18/06/2018 9:59 am
 aP
Rodeo Labs Spork is pretty good, just over 390mm though. Has sensibly placed and engineered attachment possibilities too.
Posted : 18/06/2018 11:03 am
 ton
EL VINO, mailed re brakes
Posted : 18/06/2018 11:06 am
Cempa Fairlight also has good clearance but is 398mm a/c.
Posted : 18/06/2018 2:04 pm
If I fit something is 17mm longer axel to crown, will it affect the bike handling adversely?
Posted : 18/06/2018 2:45 pm
 PJay
I just did a quick Google on 380mm carbon forks and [url= https://www.tritoncycles.co.uk/frames-forks-c6/rigid-forks-c51/futura-gravel-carbon-fork-p18115 ]this[/url] popped up. It looks to tick a lot of boxes for you (although no mudguard eyelets) but I've no idea if it's any good.
[-- Edit --] The blurb does mention mudguards.
Posted : 18/06/2018 2:57 pm
Pjay that looks like just the ticket!
Posted : 18/06/2018 5:31 pm
17mm = 1 degree slacker, you might notice it but it's not going to turn it into a barge.
£312 for a fork WTF etc
Posted : 18/06/2018 6:22 pm
Posted : 18/06/2018 7:01 pm
Good luck finding a UK-made carbon road fork - despite what the stickers on your bike say, it's almost certain that if it alloy or carbon then it was made in a big shed in Taiwan or China. FWIW British Standards were superceded years ago by CEN European Standards in 1996 - if there still was a BS, it would probably talk about chrome-moly steel and rod-brakes.
Posted : 18/06/2018 7:49 pm
Doverbiker. If you can find a good carbon company selling direct from China then it's fine and much cheaper (light bicycle for example) but there are too many open moulds available and so many ways to make them. Too much intellectual property theft and forgery.
Brant once wrote a post about it years ago and how it's a mine field and a lottery. It put me off and I need some new mtb 29er rigid forks!
Every now and then we get a post of someone who has bought carbon bars from Ali express for £12 delivered and they flex or snap.
Would you buy a carbon fork from a company on ebay or Ali express you have never heard of?
At least if the carbon products from the UK (London Road fork from planet x for example) brake you have some come back.
Have you ever heard of Ali express issuing a product recall?
Posted : 18/06/2018 9:04 pm
I've bought lots of stuff direct from China - titanium frames and fork, carbon frames and forks - it doesn't take much research to find who the reputable suppliers are. UK bike companies have a vested interest and a certain amount of 'disinformation' is put out there, despite the fact that their willingness to outsource to China that was their own downfall.  I once had someone from the bike industry tell me my self-designed, Chinese-built titanium frame would result in my painful death - kind of ignoring the fact I was designing and making stuff in composites and titanium in 1990.
Posted : 18/06/2018 9:54 pm
 PJay
[url= http://www.columbustubi.com/eng/4_2_2.htm ]Columbus' own website[/url] lists the a-c height at 382 (rather than 380) but hopefully that's not too bad.
It does appear to have mudguard eyelets.
Posted : 19/06/2018 9:18 am
