Sorry but another t...
[Closed] Sorry but another tubeless question (stans flow)
I've just got some stans flow wheels and i'm wondering what i need to go tubeless. As far as i can tell its:
http://www.chainreactioncycles.com/Models.aspx?ModelID=38829
2x http://www.chainreactioncycles.com/Models.aspx?ModelID=38830
http://www.chainreactioncycles.com/Models.aspx?ModelID=38850
Will i need one of these as well?
http://www.chainreactioncycles.com/Models.aspx?ModelID=38831
Also i've read that you can get 'normal' tyres i.e. non ust ones to inflate using just the above. Is this correct?
I've got some standard non folding 2.35 high rollers i want to fit...
Any other tips/things to look out for?
Thanks,
James
Posted : 19/04/2010 9:45 pm
Yes, normal tyres will work.
You can get the core remover, but a pair of pliers does the job too.
And yes, that's all you need.
Posted : 19/04/2010 9:47 pm
That's it exactly. Make sure you get the right width of yellow tape. There are kits out there that look like good value but most come with the narrower tape. And yep, most regular tyres work fine.
Posted : 19/04/2010 10:15 pm
