Some stupid thru ax...
[Closed] Some stupid thru axle fork questions
Am looking at building up an old DH bike, my current bike has maverick forks and the 24mm axle front hub, can I change the 24/7 hub to run 20mm axle or am I stuffed and need a new hub & wheel build too?
Do any older 170mm travel forks run a QR as I have access to a QR front wheel too...
I know I should do a WTD add and will, but am also looking for a set of servicable Boxxers from around 2000 if you happen to read this.
Posted : 12/01/2010 9:20 am
