Droper cable needed doing taped the old to the new as a pull through n it came apart..
Balls
Its times like this I miss my carbon intense as it had all tubed runs and was a doddle
This things a sod.....
So I'm going to swear and shout at it for an hour
Cotton and a rolling hitch doesn't come undone for me....
That said, I'm not buying an internal routed bike again. Changed two sets in the last fortnight, and even with no mistakes its a 20-30 minute job.
My bike this morning was replaced in under 5 minutes. Full length cable on outside of frame, ziptied on.
Bane of life as an orange owner.
You can have a lend of my park internal routing kit if you need it?
Same here. Internal gear cable and I have to fit 1.1mm internal to get the gears partially working. External and all is great.
Have you tried cotton and a vacuum cleaner? Tape off any other holes and suck the thread through to the exit? Or near the exit and go again?
I used a small screw tied to a piece of string and a strong neodymium magnet to pull it through. Piece of pee
Vacuum cleaner and cotton is my default get out of jail trick.
Done only one swear word. Old gear inner and a bent spoke....
Its like fishing but not as dull.
just swapped my dropper on my hightower v2, internal routing is a dream on that. quite surprised actually as i thought it might be a pain.
