So I just opened up...
[Closed] So I just opened up my Pikes to change the spring...
[#437860]
TFtuned instructions say there should be 3 detent springs and ball bearings under the U-Turn adjust nob - there is only one. I def didn't drop any. These are OEM Pikes on my Pitch Pro btw if that makes a difference.
So, should I worry about this or just stick the one back in there and forget about it - what do they do?
Ta
Posted : 31/03/2009 12:34 pm
They are there to 1. help the adjuster turn and 2. to give you the notch felling as you turn it.
Posted : 31/03/2009 12:36 pm
Hmm well it seems to turn ok and I can feel it clicking round - don't really use it that much tbh
I got the shop to swap the spring before not long after I got the bike - wonder if they lost the extra springs or if they weren't there to start with. Think I will just ignore it - not caused a problem so far.
Posted : 31/03/2009 12:38 pm
mine from rockshox only had 2. tft can supply them but they reccomended getting to a bearing supplier. dunno about the springs though.
the imporvement from 2-3 was noticeable easier on the u-turn, can do it from the saddle these days!
Posted : 31/03/2009 12:39 pm
You could probably rob the spring out of a pen and a shimano front hub bearing would be about the right size!
I wouldnt worry too much, its just to give an indexed feel to the knob and stop it turning of its own accord.
Posted : 31/03/2009 12:46 pm
Mine ran on just one for a while as there seems to be an unstoppable force that pulls the balls into the other holes from where it's nearly impossible to get the buggers out again...
Posted : 31/03/2009 12:57 pm
Righto, cheers.
Now I have a new problem - fitted the new spring in and the foot bolt at the bottom won't tighten up, just goes right in without biting. Shit.
Posted : 31/03/2009 1:17 pm
Arghh just realised that the new spring I got is too short - is there another travel version of the pike or something? Was the older one shorter travel?
Bastard SBR Sports!!
Posted : 31/03/2009 1:33 pm
 gamo
they've maybe sent you a rev spring?
Posted : 31/03/2009 1:35 pm
It says pike assembly on the little sticker on the packet that says when it was manufactured etc.
I have contacted them to check but they are utterly useless and it looks like it could be £40 down the drain (plus the £18 for the tyres they never sent me that they are meant to be refunding). ARGHHH!!!
Posted : 31/03/2009 1:38 pm
It is probably part way into U turn adjustment. Just compress the fork till the nut meets threads.
Posted : 31/03/2009 1:39 pm
Aha looks like you were right - nice one. Got it in ok now.
Though does the fact that it was wound part way in suggest it wasn't brand new?
Posted : 31/03/2009 2:45 pm
No, the 2 I have had were never at the max travel. Remember and grease it well!
Posted : 31/03/2009 2:48 pm
OK fair enough - thanks very much for that. Have greased it pretty well I think.
Still though, if I push down really hard on the forks with my weight on the bars, I still seem to only get to about 3/4s of the travel - is there something else that affects the stiffness apart from the spring firmness?
Posted : 31/03/2009 3:04 pm
I love following these "live" fettling reports.
How long before someone does a live web-cam of a tubeless conversion, or a Hope Pro2 bearing replacement...
Nice forks Pikes. Very nice. Love mine.
Posted : 31/03/2009 3:15 pm
If you need bearings go to ebay and type in 4mm ball bearings.I bought some a couple of weeks ago,pack of 50 decent quality ones were a couple of quid.
Posted : 31/03/2009 3:32 pm
Could you compress it further when the spring wasn't in?
Posted : 31/03/2009 3:49 pm
He never tried that - don't really want to take it apart again now 😛
Posted : 31/03/2009 3:54 pm
You're not going to get full travel by throwing your weight on the bars (well I can't anyway and I'm 90kg kitted up). Stick a zip-tie or something round one of the stanchions before your next ride. Maybe do some drops. That'll give you a good idea.
Posted : 31/03/2009 4:20 pm
