is there such a pump that is pretty small (think other smallish emergency pumps), good volume, nice attachment to presta (only need presta), and around £20...also must fit inside a camelback easily (preferable a fanny (LOL) pack too?
I know the normal answer is a topeak mountain morph, but its just a bit too big for what I want it for
I'm currently using a 10 year old mini pump which is shite, doesn't pump out much air, the attachment is shocking, but its a good small size
Topeak Mountain Morph.
But:
A) I bought the Lezyne version, like everything Lezyne it's shiny but shit.
B) I just carry a CO2 cannister for emergencies, it's a fraction of the size and I can't remember using it once this year. I've reached the point where I just carry a cannister of sealant (like a mini version of the ones you get in a car) from Decathlon and not even a tube.
As an emergency pump I've been quite surprised by one of these...
http://www.wiggle.co.uk/lifeline-hybrid-co2-mini-pump-mtb/
It's tiny (easily fit in a jersey pocket or a small saddle bag). I usually use it with CO2 and it's a good controllable inflator, but I have also pumped up a CX tyre from empty and it doesn't take that long. And it's less than a tenner.
Topeak Mini Morph is not bad. It is quite a bit shorter and narrower than the Mountain Morph. Though smaller volume, so would take a bit longer to pump up the tyres.
Or Topeak Racerocket MT if you want even smaller.
had seen the lezyne Micro Floor Drive HV, looks a fair bit smaller than the mountain morph and not as wide as well as long....any good?
will have a look at slightly smaller topeak versions then too
2xCO2 and an Innovations nanoflate. Two tubes and some Topeak patches for a third+ repair. The Topeak Micro is fine on the frame, smaller will just about get you rolling, but by then I'd be so miserable on my third puncture, I'd probably be on a train!
Know how to use a CO2 device properly. Avoid Lezyne if you want to keep the valve cores intact!
Lezyne seems to have fixed this infuriating querk with the ABS button. However, they still seem to fall apart if left in a bag for too long!
Dont really want c02 tho i appreciate the unput 🙂
Just want a smallish pump that wont take for ever and easy to attach etc
Im edging towards the racerocket MT as it looks about same size as current crap one but should be easier and more powerful
I got a road morph when I got a bum bag and found the mountain morph wouldn't fit. Lower volume but pumping is easier. Easily got my plus tyre way above the pressure I need quickly the other night. I've had it a few years now and it's been reliable.
Specialized do the air tool big bore which certainly shifts a lot of air . At £35 it's a bit over your budget though unless somewhere is selling them cheap . https://www.specialized.com/us/en/equipment/accessories/air-tool-big-bore-pump/131592
Cheers good spot as i get decent discount off spesh stuff too ill check it out
And ta del will check out the roadue version too
I've got a top peak micro rocket. It's small (obvs!) but pretty good. It takes a while to pump up but it works. I also carry CO2 so the pump really is an emergency back up.
Fits easily in a pocket
