Anyone know if they are the same .. ??, I have purchased a 10 speed SLX triple and overlooked the Dyna-sys 10 speed chain compatibility issue as Im mixing it with 10 Speed SRAM.
I think it'll be cheaper to change the rings than sell the crank and buy another. I'll just put 9 speed rings on.
cheers
Err, just use it with the Sram stuff, it'll be fine.
Really .. chain keeps getting dropped off the middle ring to lower, its new SRAM chain so thought it might be the compatability issue as Shimano 10 speed are directional etc ..
Sounds like a front mech alignment issue
Nope, sram chain worked fine for me on 10 speed SLX. Once I snapped it I switched to KMC, no noticeable difference though.
Cool, i'll re-check.. Thank you !
chain too long?
not enough tension in rear mech?
