SLX chainset and bo...
[Closed] SLX chainset and bottom bracket question
 SiB
Probably a very straight forward answer but im sick of handing cash over to LBS for jobs I could probably easily do so I need clarification please.....
currently have an external bottom bracket, just going to purchase a SLX chainset which comes with bb...how do I know the bottom bracket will fit?
thanks
Posted : 24/05/2011 10:16 am
How do you know the new BB will fit your frame you mean? Because all MTB frames are the same bottom bracket thread and there are spacers included to shim it between the two different shell widths.
Posted : 24/05/2011 10:18 am
if it's for a standard mountaion bike then it 'just will' fit - they're all the same BB's you just change some spacers about depending on how wide the BB shell on your frame is.
Posted : 24/05/2011 10:19 am
 SiB
Thanks
Posted : 24/05/2011 11:03 am
 Dair
I had the same anxiety last year when fitting a new chainset. It is surprisingly easy if you follow the instructions, which have very few steps. Just make sure you measure the BB shell and use the correct spacers.
Posted : 24/05/2011 11:06 am
Fitted my first SLX chainset last year. Even for butter fingers here, it was really easy - as said just follow instructions and ensure you choose the right spacer in the kit. The BB even comes (lightly) lubed for you.
Posted : 24/05/2011 11:13 am
