SLX Bash Guard Repl...
[Closed] SLX Bash Guard Replacement
Just a quick question. will this
http://www.chainreactioncycles.com/Models.aspx?ModelID=40422
Fit my SLX double chain set?
This one,
http://www.chainreactioncycles.com/Models.aspx?ModelID=28019
Thanks
D
Posted : 16/01/2012 9:42 pm
 feed
Yes
Posted : 16/01/2012 9:48 pm
Thank you very much.
Posted : 16/01/2012 9:50 pm
Is this a record for a civil and seemingly correct answer from the stw massif?
Posted : 16/01/2012 9:51 pm
I'll let you know if it fits!
Posted : 16/01/2012 9:53 pm
Yep, it'll fit. Although neither ad states the BCD (Bolt Centre Distance), four bolts are generally 104mm.
I think it'll look quite cool, go for it and post pics please!
Posted : 16/01/2012 9:57 pm
white one ๐Ÿ™‚
Posted : 16/01/2012 10:07 pm
You knew it was too good to be true!
Just one small point - Shimano beefed up the plastic around the bolt holes on their M665 bash. This was a good idea IMO, as I had an E-13 bash fail at this point, but means they needed to shorten the crank spider arms by a couple of mm on the SLX M665 crankset to accommodate it.
So, if you now go and fit a 'standard' bash guard there will be a few mm gap between the arms on the bash and the spider arms on the crankset. You'll only notice it if you look hard, and the bash is still held securely by the bolts, but just thought I'd let you know in case a [i]perfect[/i] fit is important to you...
PS: This isn't an issue with the SLX M660 triple, XT M770, or any other cranks with a 'standard' fitting for the big ring/bash.
PPS: It also means that if you try and fit an M665 bash to one of the standard cranks, you need to do a bit of filing to make it fit!
Posted : 17/01/2012 10:51 am
