Slight overpackagin...
[Closed] Slight overpackaging from CRC 🙂
When this came I thought they'd sent me a track pump by mistake:
[url= http://jsbmwg.bay.livefilestore.com/y1pVWMlODAikhS5Pae041tkvHwtq_YjHZIlTGV3HAnfgf59ow0fwk0HR1ZmJo971EK2xUCIl2inQdx2mhL8otgpjGxqy5m4CtI7/DSC_0473.jp g" target="_blank">http://jsbmwg.bay.livefilestore.com/y1pVWMlODAikhS5Pae041tkvHwtq_YjHZIlTGV3HAnfgf59ow0fwk0HR1ZmJo971EK2xUCIl2inQdx2mhL8otgpjGxqy5m4CtI7/DSC_0473.jp g"/> [/img][/url]
and check out the quality of this drilling on the Hope mandrel:
[url= http://jsbmwg.bay.livefilestore.com/y1pEgDHqcW_NskxXxdUCLCjT3mTrpg43BrNdWSC1kHZ46K_d-zjFcEgjouoKAvZDr7ZigDxfBNg-gbH5I272fB4ZZ6Qxjtu-NOY/DSC_0486.jp g" target="_blank">http://jsbmwg.bay.livefilestore.com/y1pEgDHqcW_NskxXxdUCLCjT3mTrpg43BrNdWSC1kHZ46K_d-zjFcEgjouoKAvZDr7ZigDxfBNg-gbH5I272fB4ZZ6Qxjtu-NOY/DSC_0486.jp g"/> [/img][/url]
Posted : 09/02/2010 12:02 pm
Looks fairly standard for a deepish drilled (non reamed) hole in mild steel to me
Posted : 09/02/2010 12:09 pm
Why does it need to be any better quality? Cheap and fast it will not effect its use or quality.
Posted : 09/02/2010 12:14 pm
Yup, tis a normal quick deep drilling. Does it affect the product performance?
it's just in marked contrast to the outside which is satin polished and laser etched with the Hope logo. I know it doesn't matter as the bore just gives clearance to the axle. It looks as if they used a blunt 'drill'.
neither does the high quality finishing on the outside...
It's a handlebar box i think..
useful size if ever you sell something on to someone.
Posted : 09/02/2010 12:18 pm
Its just drilled for, as you say, clearance. No need to waste time/money getting a better surface finish.
Btw, I received one of those pumps from crc last week, its a beast, well pleased with it 😀
two of the lads in our group have the same pump..
very effective bit of kit..
Posted : 09/02/2010 12:19 pm
I suspect they dont have a box that fits the Topeak pump and a hope mandrel exactly, so the one you have was the nearest in size.
You should have a look on the register and search for over packaging if you want to see how to do it properly.
You call that high quality?
You really shouldn't start threads if you don't know what you are talking about
Posted : 09/02/2010 12:21 pm
 ton
what is a mandrel
Posted : 09/02/2010 12:23 pm
"You really shouldn't start threads if you don't know what you are talking about"
this is stw we're talkign about...
well, it seems I don't see the kind of bespoke engineering you're accustomed to, but I thought the outside looked quite neat for something I was going to belt repeatedly with a hammer 🙂
[url= http://jsbmwg.bay.livefilestore.com/y1puR55rDvxuNj7lPEWNQNrAZEUh94dmV0vjt4I-sdvPe9_ZualVVQaMv4_aKN-CWHtolpzKvYJVHsWyaN_vNY7h6ZaQVvY0l48/DSC_0490b.jp g" target="_blank">http://jsbmwg.bay.livefilestore.com/y1puR55rDvxuNj7lPEWNQNrAZEUh94dmV0vjt4I-sdvPe9_ZualVVQaMv4_aKN-CWHtolpzKvYJVHsWyaN_vNY7h6ZaQVvY0l48/DSC_0490b.jp g"/> [/img][/url]
surely that would be setting a new precedant ?
Posted : 09/02/2010 12:34 pm
what is a mandrel
something like a tool for assembling things
wiki says "object used to shape machined work; a tool component that grips or clamps materials to be machined; or a tool component that can be used to grip other moving tool components."
in which case perhaps I should have called it a drift ?
Posted : 09/02/2010 12:35 pm
"What is a mandrel"
Isn't it a monkey/ape with a brightly coloured face?
A
This is a mandrill isn't it?
Posted : 09/02/2010 12:36 pm
I though it was a type of duck.
Posted : 09/02/2010 12:37 pm
 goog
lol
 mjb
My particular favourite, puts CRC to shame...
http://www.theregister.co.uk/2008/07/18/hp_packaging/
Posted : 09/02/2010 12:39 pm
This is another good one - http://www.bitterwallet.com/more-packaging-disasters-size-isnt-everything/24811
Posted : 09/02/2010 12:40 pm
yes, I'd seen that one, and it is shocking 🙁
Posted : 09/02/2010 12:45 pm
I would call that a drift! How much was that "drift" mr barnes? That looks like a four year old with a hobby lathe could make it.
Posted : 09/02/2010 12:50 pm
HOw much was that "drift" mr barnes?
£9.99 for the two 🙁 Shocking I know, but they do work far better than using a socket...
Posted : 09/02/2010 12:52 pm
I'm guessing the laser/engraving doesn't cost much, the finish is otherwise "basic" IMO
Posted : 09/02/2010 1:18 pm
I'll take your word for that, however, the surface [b]is[/b] ribbed for extra pleasure 🙂
Posted : 09/02/2010 1:19 pm
 cp
fairly practical manufacturing really - The outside diameter has been turned for a good size match foe the bearing (hard to buy steel bar exactly the right size, though it looks like they've got close - they've just 'cleaned up' the diameter). drill a hole through the middle for clearance, bob's your uncle. £10 quid end user price for two is pretty reasonable really.
Posted : 09/02/2010 1:28 pm
 cp
oh, and it looks like the laser marking was done quickly in a static position rather than rotating it to keep the laser focused - see the 's)' is barely visible at the end of 'bearings)', and the Hope logo is dark on the 'OP' of HOPE and gets lighter towards the edges... because the laser is going out of focus as the material drops away.
Posted : 09/02/2010 1:31 pm
I think that was the depth of field of the camera and reflection from the edges of the etching - on inspection the lettering is sharp all the way round
Posted : 09/02/2010 1:35 pm
