Singlespeeding in s...
[Closed] Singlespeeding in snow - tips?
 jonb
[#2238649]
Before I reach for my geared bike and the comfort of 22:32 for ploughing through snow has anyone got any advice for singlespeeding in snow?
Currently running standard 32:16 and 2.1" tyres. I have fatter tyres but they aren't really knobbly (more like summer race tyres).I can go down to a 32:18 ratio but don't have any spares.
I'm strugling to keep the back wheel from spinning out. Or when I have grip I'm virtually track standing as it's such tough going.
What tyre sizes and ratios do you lot use?
I'm in Newcastle so we are currently measuring our snow fall in feet not inches which is why I'm having so much trouble.
Posted : 30/11/2010 12:24 pm
studded tyres are your friend
Posted : 30/11/2010 12:26 pm
get gears on. Bit like saying i have a sports car and a 4x4. Cool, continue using the sports car as much as you want but realise there's a time and a place for the 4x4, and that time is now my friend
Posted : 30/11/2010 12:27 pm
4" and 36/19
Posted : 30/11/2010 12:33 pm
I towed the kids trailer on my 32:16 this morning.
The classic 2.35 Nev/BG combo.
But we're measuring our snowfall in mm, not feet.
Posted : 30/11/2010 12:35 pm
you need to sit down more. which unless you have iron knees can mean switch to a lower ratio
Posted : 30/11/2010 12:40 pm
Mocha
Size isn't everything you know..... 😉
Posted : 30/11/2010 12:41 pm
depends really. i rode my SS all throughout last winter and the great thing about it is that you will not suffer any of the effects that freezing temperatures will have on your gears. i was riding in wales at the weekend and realised just how much of a pain in the ass frozen mechs are. and besides, the bits where you can actually ride you'll probably not need gears for anyway.
chuck on some 2.4 rubber queens and you'll be laughing.
Posted : 30/11/2010 12:52 pm
 Sam
Time to break out the xc skis then IMO
Posted : 30/11/2010 1:02 pm
Kenda Small Block 8's 700c x 32.
42 x 16 ratio fixie.
All good fun in the snow!
Posted : 30/11/2010 1:04 pm
my tips would be to fall off a lot, laugh every time, and don't expect to cover the same distances at the same speed.
From experience.
Posted : 30/11/2010 1:05 pm
I was just about to convert my commuter into a singlespeed! Having second thoughts now.
Posted : 30/11/2010 1:11 pm
 gazc
i'm in newcastle also, finding some reasonably knobbly tyres with custom intalled spikes (1/2 inch steel screws with a dh tube liner in an old panaracer fire 2.1/geax barro combo) working a treat at the moment except for the really deep slushy stuff - been running gears too and preferring the range of gears to control traction more than my usual ss
Posted : 30/11/2010 1:16 pm
try the tandem with jerry technique always works for me
Posted : 30/11/2010 1:19 pm
What jonv said times a million 😀
On anything but ice, spiked tyres are pointless (and sometimes worse than that). A good mud tyre is what you need, especially on the rear. Something with high knobs that will dig in and drive you forwards without slipping. Trailraker is a good but narrow option, and I'm finding a Minion DHR to be ok just now too. Keep seated as much as possible, and if you can't do that then try to force back as much weight as possible while you're standing (like hanging off the back when you go off drops, etc, except uphill). Pedal as evenly as possible, and pray.
Your gear ratio is probably a personal thing. I have never had a problem using anything but the 34:16 I use in summer too.
Posted : 30/11/2010 1:20 pm
Let a bit of pressure out of your tyres and keep those pedals turning smoothly. Like riding in sloppy mud but cleaner when you fall off!
Posted : 30/11/2010 1:41 pm
I have had a real blast this morning on the SS. Also got small block 8's on but we only have an inch of the white stuff and no hills to speak of.
Good thing was that the snow was still crisp enugh to give the front loads of purchase but the back slipped easily so it was speedway cornering all the way. 😀
Posted : 30/11/2010 1:45 pm
Last winter i ran 32:17 with 2.1 mountain king rear and 2.5 diesel front at about 20/15psi when riding in snow and it was mega! I rode more in the snow than not and I have felt like a more confident rider ever since!
Posted : 30/11/2010 1:58 pm
Mostly all said already, but lower gearing, lower pressures, and ride smoothly. Studs a help when there's ice underneath but no advantage in packed snow.
For real snow fun you need a fatbike 🙂
Posted : 30/11/2010 2:41 pm
Personally I'd go with narrow-ish tyres. I rode home from work this AM at 5:30 and I run 2:1 with Conti Explorer 2.1s (which come up quite narrow). We ain't got a lot of sno here though. 2 inches at most. If you stand bend elbows, nose down by bars and bum as far back as possible. As said when sitting try to keep weight back but be careful of taking too much weight off front, esp on turns so that you don't wash the front out.
Posted : 30/11/2010 2:48 pm
After my advice earlier, I went out on the geared bike with tyre pressures dropped. Spent most of the ride in 22:low!
Posted : 30/11/2010 10:18 pm
 igm
32x18 on a rigid 29er with 2" MudX tyres. Fine in up to 8" of snow.
Keep the momentum up. If you let it slow it's killing.
Posted : 30/11/2010 10:46 pm
34:16 2.1 trailraker on the rear.
When I'm climbing on snow or mud I actively pull back on the bars and dreive feet forward at the same time as if to force the rear down without lifting the front. Seems to help give me some more grip in the soft stuff or at least get down to the firmer stuff.
Hth
Posted : 30/11/2010 10:54 pm
I switched to my geared bike with the grippy grippy tyres on today.
Gears were slipping around all over the place though after it had been freezing in the bikeshed all day.
Posted : 30/11/2010 11:15 pm
Singleslowing in snow
much like singleslowing in mud, just get off and walk:
Posted : 04/12/2010 12:13 pm
Weirwolf 2.55 at low pressure were great for upto 5" of snow but much more and It's too much on unbroken trails . Had a great ride last nite , pardon the poor getting dark camera pic, the bike stands up by itself 😉
Posted : 04/12/2010 12:31 pm
1.8" Tioga Factory XC
38:14 (but it's flat in Lincolnshire!)
Posted : 04/12/2010 1:56 pm
Cannock Chase - 32/18 - Nobby Nics on the back - first sign of slippage on climbs, sit down for a couple of peddle strokes.
Really impressed with the NNs....
Posted : 04/12/2010 2:07 pm
Skinny tyres will be best for snow. Last week we went out in 4 inches of the stuff and the guy who usually stays at the back was flying ahead of us a lot of the time on his 1.8s.
Posted : 04/12/2010 2:30 pm
